February 24, 2016, 02:24 |
Swirl ratio fluctuates
Gomathi shankar
Iam doing an analysis of port flow in Ansys Fluent. In that i need to calculate the swirl ratio at a plane. For that i created a field function as follows:
(x*Vz-z*Vx)/(x*x+z*z) I created a surface monitor for mass averaged swirl ratio at a required plane and also for mass flow rate at outlet. The problem is that the swirl ratio does not converges even if the solution is converged. The mass flow rate converges. If i see the plot of the mass averaged swirl ratio at the plane it keeps on fluctuating. The simulation conditions are inlet: pressure inlet atm pressure outlet: pressure outlet (-2451.5 Pa) Model: Realizable k-epsilon I need to know that the problem is with the field function or with the simulation setup. Have anyone experienced similar situation? Thanks |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
measure of swirl ratio | cnaksoy | STAR-CD | 0 | August 31, 2014 11:04 |
Swirl ratio failure in remeshing in CFX | a_cucen | CFX | 15 | March 4, 2013 16:28 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
swirl ratio reduction | sijin james | Siemens | 3 | May 10, 2007 06:12 |
