Moving reference frame in Gambit
Old   March 9, 2007, 03:04
Default Moving reference frame in Gambit
Hussein
How can I define a zone as Moving Reference Frame in THE GAMBIT SOFTWRAES ; CAN I ? since i know that we can do that using fluent an dnot gambit , but i heared that i shuld do that in gambit while workin on my final year project;
I appreciate your reply as soon as possible ;
Thanks
Old   March 9, 2007, 13:27
Default Re: Moving reference frame in Gambit
lee
It is not defined in Gambit, should be in fluent. Define proper boundary condition for Moving reference frame in Gambit. You can refer to the tutorial.
Old   March 9, 2007, 14:48
Default Re: Moving reference frame in Gambit *NM*
Hussein
Old   March 9, 2007, 14:55
Hussein
Hello , yhanks for your reply , my problem is the following :
I have a cube , where in the cube i have a wind turbine , I want as a first step to check wether i have conservation (check if i have the sam eresults coming and going out of the blade), to do that , i created another cylinder , and substracting the volume 1 from the cylinder , so i got a volume 2 .
Unfortunately , i also was unable to mesh this volume , i dont know why . since i click on mesh the volume cursor , but it is meshing the volume as a faces , . Do u know how can i mesh it an dwhat possibly is my problem can be solved ?? also , i used , velocity inlet b.c, outlet b.c , and wall as a BC; what do u think ? is it good or bad ?
I will appreciate your helps !!!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Moving Reference Frame or Sliding Meshs caohan FLUENT 0 May 11, 2010 13:34
Moving reference frame sadanand FLUENT 0 February 5, 2009 23:18
Moving reference frame case rengu OpenFOAM Running, Solving & CFD 0 November 20, 2007 10:00
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
