Convergence problems... need help urgent!!
Old   March 15, 2007, 00:58
Default Convergence problems... need help urgent!!
HSeldon
Hi folks, I´m dealing with a valve in a duct, 0.05 meter of diameter and long enough to avoid reverse flow and to get a full developed flow. I have to use nitric acid and the mass flow is 15 liters/sec. The problem is that I have to simulate the valve when initiates the opening, so the velocity between the valve and the tube wall is increased very high. Wich models and settings in general are prefered for this kind of problems?
Thanks for your time.
H
Old   March 15, 2007, 01:04
Default Re: Convergence problems... need help urgent!!
HSeldon
Oh! I almost forget... The fluid is supossed to be incompresible. So what density model should I use? constant?
Thanks.
Gas-liquid vertical separator, problems with convergence juliom Main CFD Forum 0 October 5, 2011 20:20
Convergence Problems Carlos FLUENT 0 March 12, 2007 02:44
NACA0012 Convergence Problems StudentAndrew CFX 6 November 21, 2005 06:49
Convergence problems Simone Siemens 5 June 29, 2005 10:48
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
