problem about the change colors in Fluent
Old   March 18, 2007, 07:25
Default problem about the change colors in Fluent
lisa
Hi guys,
I need your help!!!
I can not change the color of background of the plot windows from black to white in Fluent. If I did so, the forground will change too. Do we have to change it under unix?
Thank you very much for your help!!!
Best,
Lisa
Old   March 18, 2007, 08:03
Default Re: problem about the change colors in Fluent
Shaik Rizwan
Well u can change it. once u have the contour plot right click on the title bar (the one on which u see minimize, maximize and cross on top corner of a window). go to page setup and in options chek reverse fore/back gound.
hope this helps. Regards
Old   March 19, 2007, 09:56
Pablo
At the command window write:
display-->set-->colors-->background-->"white"-->foreground--> "blue"
good luck
Old   March 19, 2007, 10:34
lisa
Thank you very much for your help. But it seems not work. there is no reponse when I change the reverse for/back ground in the title bar. I am using fluent 6.1.26 in pc. Regards, Lisa
Old   March 19, 2007, 10:36
lisa
Thank you very much for your help. But it seems not work. there is no "set" after "display" in my pc. I am using fluent 6.1.26 vision. Regards, Lisa
Old   March 19, 2007, 10:42
Rizwan
May be u r not doing it correct but for sure it is how it works. And I strongly advice that u have a further careful look at the procedure.
Regards
Old   March 20, 2007, 06:43
farhath
Hi, save> hard copy > jpeg -select color from gray scale , (do not change or deselect reverse background tab). if the pic in display is in black background,the pic saved will be in white back ground and vis versa.
hope it helps F Alam
Old   March 20, 2007, 07:50
lisa
It works after the hard copy.
Thank you very much.
Regards,
Lisa
Old   March 20, 2007, 07:55
lisa
Thank you very much for your reply. I will try again. but it doesn't work for sure in my pc. But the hard copy (like what farhath said)is working very well. Regards, Lisa
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
