evaporation from surface with jet impingement |
March 28, 2007, 12:54 |
Hello, there's something strange.. We are modelling a jet impingement drying (steady state, 2d axisymmetric). We want to simulate the evaporation from the surface impinged (a wall). We activated species transport with 2 species: air and water vapor. We built a UDF to specify mass fraction of water vapor at wall: it calculates the mass fraction corresponding to saturated conditions for water vapor f(T, P). We set 0% mass fraction of H2O at the inlet
Results: INLET mass flow: 1,1374 10e-04 kg/sec mass fraction of AIR: 99,6 % mass fraction of H2O: 0.4 % OUTLET mass flow: 1,1374 10e-04 kg/sec (the same) mass fraction of AIR: 93,7 % mass fraction of H2O: 6,3 % It seems that air disappears and water is created. It isn't a physical solution, i think. What we want: water vapor is created and diffuses from surface to the fluid but i don't want to lose air mass. using a UDF define_source? P:S: Other settings are: T wall = 320 K, vel inlet = 10m/sec, T inlet =390 K, press outlet = 0 Pa (far from inlet, so without reversed flow). The mesh is fine enough (y+=1)so we used enanched wall treatment with viscous k-epsilon model. |
jet two phase spray and evaporation | Tag | OpenFOAM | 1 | March 18, 2011 11:51 |
impingement jet modeling in GAMBIT | morteza08 | ANSYS Meshing & Geometry | 12 | March 14, 2011 04:10 |
Simulation of Evaporation of a Semi-spherical bubble on a heating surface | Osama.Shawky | CFX | 1 | March 30, 2010 18:20 |
Free Surface Jet Impingement | John | FLUENT | 0 | July 14, 2006 03:45 |
a doubt with jet impingement | G.Balakrishnan | FLUENT | 2 | November 21, 2000 15:17 |
