Error and cannot iterate
Old   March 30, 2007, 12:34
Default Error and cannot iterate
Sangeeta
When ever i interpret a udf and then initialise Fluent gives this error Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Can any one help me. Thanks in advance.
Old   April 2, 2007, 02:42
Default Re: Error and cannot iterate
Bogdan
What functions do you have in your UDF? If you use UDS and UDM be sure that you enabled them.
Old   April 2, 2007, 11:49
Sangeeta
Bogdan, I use them and i have enabled them also
Old   April 2, 2007, 12:44
Bogdan
I never use the interpret option for my UDF, I always use the compile option, so I suggest to compile the UDF and try again. If you still get the segmentation fault, maybe it's better to post you DEFINE_INIT function to have a look.
Old   April 4, 2007, 06:08
Sangeeta
Bogdan, I have used DEFINE_INIT macro also. But while iniatilising the solution it again gives the same error.
Old   April 4, 2007, 22:06
suvash
Hi Sangeeta, You can send your UDF here and have a look. Then may be we can give you the solution...
Suvash
Old   April 5, 2007, 05:23
Sangeeta
here is my udf Suvash,
# include "udf.h" enum { Ar, Ai, N_REQUIRED_UDS };
double mu0 = 12.56e-7; double omega = 18.84e6; double x[0];
DEFINE_PROPERTY(cell_conductivity,c,t) {
double cond = 3.078e-23;
begin_c_loop (c,t)
real temp = C_T(c,t);
if (temp < 8000.)
cond = 2.26e6* exp(-6.21e4/temp);
else if ( temp > 8000. && temp < 15000. )
cond = 1.96e5* exp ( -4.26e4/temp);
else
printf ("The temperature is higher than15000");
C_UDMI(c,t,0) = cond;
end_c_loop (c,t) }
DEFINE_INIT(inlet_Atheta,d) {
cell_t c;
Thread *t;
Domain *d;
thread_loop_c(c,d)
C_UDSI_G(c,t,0)[1]=0.;
C_UDSI_G(c,t,1)[1]=0.;
DEFINE_SOURCE(Ar_source,c,t,ds,eqn) {
real x[ND_ND];
C_CENTROID(x,c,t);
ds[eqn] = mu0*omega*C_UDMI(c,t,0);
return -C_UDSI(c,t,0)/(x[0]*x[0])+mu0*C_UDMI(c,t,0)*omega*C_UDSI(c,t,1); }
DEFINE_SOURCE(Ai_source,c,t,ds,eqn) {
real x[ND_ND];
C_CENTROID(x,c,t);
ds[eqn] = -mu0*omega*C_UDMI(c,t,0);
return -C_UDSI(c,t,1)/(x[0]*x[0])-mu0*C_UDMI(c,t,0)*omega*C_UDSI(c,t,0); }
DEFINE_DIFFUSIVITY(Atheta_diffusivity,c,t,i) {
double x = 1;
return x; }
