March 30, 2007, 13:47 |
DMP mass flow rate
I am working on a sampler case using the discrete phase model in FLUENT. I was wondering what the mass flow rate you set in the injections window does. It seems to me that if you specify a particle diameter, particle density, and an initial velocity that the mass flow rate would be set by these parameters. The problem seems to be over specified. I know this is not the case and I am hoping someone could correct my confussion. Thank you all in advance.
-Don |
March 30, 2007, 17:34 |
Re: DMP mass flow rate
In reality, there could be say a million particles per second entering a domain, but you only have computational resouces to model a thousand. So each of the thousand is representative of many more particles. There is a factor that lets Fluent know how much of the overall particulate phase is represented by each particle.
April 2, 2007, 11:14 |
Thanks for the quick response. That helps a lot. The FLUENT manual does not make much mention of this fact.
April 17, 2007, 02:30 |
what is the factor u r talking about? In what way fluent will do correction for those things? As i have understood it calculates for the value of parameters we have given.
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 09:58 |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 20:33 |
Mass Flow Rate is not converging | destgir448 | CFX | 5 | December 11, 2010 05:55 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 07:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
