gas turbine combustor model - HELP!
Old   April 8, 2007, 20:39
Default gas turbine combustor model - HELP!
Phil
I'm modeling a tubular combustor with swirler& vane passage fuel injection as part of my PhD and I'm having big problems with the combustion model.
For these swirling combustion flows the finite rate/eddy dissipation model is essential but when I use it the flame goes out eventually after around 25 iterations even when having the outer wall at 1500K and patching in the temp of 1300K.
The boundary conditions were worked out by my supervisor and previous theses confirm them. The aerodynamics are spot on but when adding combustion (methane) the flame keeps going out for this model. The eddy dissipation model can be used but combustion occurs where the flow velocity is very high so flame should be quenched. I wrote a UDF to halt reactions > 80,100,120m/s but results are still not great but more sensible.
Old   April 11, 2007, 06:27
Default Re: gas turbine combustor model - HELP!
James Willie
hi,
did u add products (co2 and h2O) in the reaction zone? To initiate the reaction, you need to do this.....add say 0.01 of h2O and co2 just to artificially begin the reaction. These values will eventually vanish after a few iterations. This should help. If not, let me know
James
Old   April 11, 2007, 07:26
Phil
The reaction still goes out after around 20 iterations. The only way I've found to keep it going is to have a hot wall at the reaction zone. I'm hoping it's just a drawback of using the basic species transport - finite rate/eddy dissipation models. It does mention difficulties with maintaining the reaction in the documentation.
regards phil
Old   April 11, 2007, 08:22
James
is your mixture lean or rich? If it is lean, then i suspect you are very close, if not below the lean flammability limit.....in that case, you will have to consider increasing your fuel mass flow a bit...yes your equivalence will go up a bit but that could solve the problem.
You might be experiencing lean blow-out problems....this is the case when the mixture is too lean
Let me know how it goes James
Old   May 1, 2007, 09:18
mohamed saleh
i'm pleased to know you,please help me to find the following: all files is required: data base,mesh,case,data and analysis file
Old   May 1, 2007, 10:29
Phil
James,
I was using the wrong model - I needed the finite rate combined with eddy dissipation model because where the fuel is injected the flow velocities are too high for combustion to occur.
I may experience the problem you suggested when I move to detailed reaction mechanisms though.
Thanks for helping.
Phil
Old   May 2, 2007, 02:25
James
Hi Phil,
Pleased to know that you've been able to figure out the problem. I thought from the onset, you were using both the finite rate/eddy dissipation model. I guess you know why this model works best with gas turbine combustion?
I am using the same model for my work. The finite rate chemistry model works too but it doesn't account for turbulent-chemistry interaction, even though it is better with regards to chemistry and can capture very well the effect of varying equivalence ratio on the flame speed. The combined model cannot do that since after the ignition, the turbulent mixing rate is almost always bigger than the arrhenius rate and so the rate is taken as the former.
Good luck.
James
Old   May 2, 2007, 06:40
Phil
James,
I've just read over my messages and at this point I was using the finite rate/eddy diss model but the flame keeps going out.
I tried what you suggested with initialization but the only way I found to keep the flame going was to have the outer wall at roughly the flame temp, or just below it to avoid affecting the temp scale in the contour plots.
I'm moving on to detailed reaction mechs soon and then onto biofuel so I'm leaving these problems behind for now but I'd be very interested to hear what you are doing for your work.
Where are you based? Will you publish any papers? I think I'm going to try and publish my first paper in the ASME journal this year as the next conference is in Monte Carlo!
Phil
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Gas turbine load problem hashimbukhari Main CFD Forum 2 July 24, 2010 03:48
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Setting up gas turbine blade geometry for meshing sherifkadry Main CFD Forum 0 June 1, 2009 16:28
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
