how to make grid in gambit?
Old   May 4, 2007, 02:22
Default how to make grid in gambit?
pankaj verna
hi i m working on single phase flow in packed bed. but i m not able to make grid in gambit. can anybody suggest me how to make grid in gambit.
the specifications are
dia of packed bed id 46mm od 50mm dia of packing spheres 28mm
Old   May 4, 2007, 09:04
Default Re: how to make grid in gambit?
Phil
DO THE TUTORIALS/ READ THE USER GUIDE
Old   May 4, 2007, 09:36
Phil
I would prefer it if you posted messages rather than sending to my personal email.
For complex geometries try using the tgrid scheme to create a mesh.(In gambit rather than the tgrid program)
For a better mesh you want to split the large complex geometry into smaller simpler ones.
You can use the cooper tool to extrude 2d meshes through a 3d volume, resulting in a very good quality mesh. This however takes experience and it depends how much you need to learn grid generation.
For cooper extrusion, learn to use the link face meshes function to link the source faces.
You need to look at the tutorials descriptions and user guide yourself and decide which ones would help you rather than asking others to do your work. Everyone who has cfd experience had to gradually work at it.
ALSO DO RELEVANT FLUENT TUTORIALS TO UNDERSTAND WHAT YOUR MESH SHOULD CONTAIN/ BE LIKE.
hope this helps.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
how to make grid in icemcfd agung wulan piniji CFX 1 August 23, 2008 00:50
GAMBIT can't make it work. Achilleas FLUENT 0 December 30, 2006 14:21
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
