Ahmeds Body 2D Cd calculation
Old   May 6, 2007, 07:01
Default Ahmeds Body 2D Cd calculation
Sinem Sas
I'm working on Ahmed's Body flow analysis Does anyone can inform me on how to calculate the pressure drag, forexample at slanted rear end. from solve-monitor-force i found cd about 150, that is more than 100. how can i fond reasonable cd values? thanks for attention.
Old   May 7, 2007, 15:33
Default Re: Ahmeds Body 2D Cd calculation
Anindya
See that your reference velocity and area is set correctly. Most probably you did not change those and fluent is using the default values of 1m/s and 1m^2. You can change these under report/reference value. Anindya
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Calculation of Cd on axisymmetric body Mahbub FLUENT 10 February 11, 2008 23:53
Warning 097- AB Siemens 6 November 15, 2004 04:41
Calculation of a cube (bluff body) Sepp FLUENT 3 May 15, 2001 08:20
