Separation
Old   May 18, 2007, 04:19
Default Separation
Giannis
Hi guys,
When looking at simulation results, how can I actually know if separation did occur or did not occur?
Thanks! Giannis
Old   May 18, 2007, 06:14
Default Re: Separation
Farhat
well you can judge from the streamlines, which you can plot using DISPLAY option in the menu.
Old   May 18, 2007, 07:28
Giannis
How can I do that? Which option is it? Is it the option path lines under display?
Im in that menu but I cant actually display them, particularly what do I have to do? By the way, im running a 2-d simulation, does this make a difference?
Old   May 19, 2007, 02:04
Matt
The common characteristics of 2D flow separations are:- 1) The boundary layer detaches from the wall 2) Occurrences of reversed flows and swirls
When the boundary layer detaches from the wall, a wake of slow moving air flow is formed downstream of the body. This can be illustrated using velocity contours and streamlines.
Furthermore, there will be reversed flows, just downstream of the separation point. Depending on the severity of the separation, swirls might occur. Both can be illustrated with velocity vectors.
Old   May 19, 2007, 13:17
farhat
Using pathlines option u can generate streamlines, further u can also infer from velocity vectors.
Separation Point over a NACA 0012 Franny CFX 9 October 12, 2011 10:01
wall function and flow separation O.D.Y. FLUENT 1 October 3, 2011 16:27
How to identify flow separation region? Cheng CFX 2 November 29, 2006 07:26
Separation An Modh Coinniolach FLUENT 4 April 1, 2002 11:31
Euler + separation again Oliver Main CFD Forum 23 June 19, 2001 12:47
