How to export data
Old   May 28, 2007, 12:17
Default How to export data
Ferdinando
Hi all, a simple question i think: i'm using Fluent. My geometry is: a box (air domain),a tube (water domain), a UV lamp. The radiation travel from the lamp to the water domain passing through the air. I have a second simulation with only the same tube (in identical coordinates). I want to export incident radiation data from the first case and import it only to water domain in the second simulation (always using Fluent). Is it possibile? How? Thanks in advance.
Export data in text file Eferal FLUENT 5 April 13, 2018 10:33
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
