injections
Old   June 1, 2007, 11:08
Default injections
Donia
hi, i 'm working with injections on surface!how to specify the number of injections? thanks
Old   June 1, 2007, 12:21
Default Re: injections
R.
I don't think you can.
All it ever did for me was start a particle at each centroid of each facet.
R.
Old   June 1, 2007, 13:08
Donia
thanks but i think it 's possible: a colleague worked on the same think,i have his work and in the same conditions he put more injections! the pb i can't contact him!t'll try and if it's ok i'll tell you!
Old   June 2, 2007, 05:48
Prasad Dudhgaonkar
If I have understood your requirement correctly I would like to suggest you that you can use file injection with a specific format. User manual gives necessary information. For ready reference an example is given below. All the values should be in SI units.
((x y z u v w dia temp mass) INJECTION_NAME) e.g. ((0.00E+00 1.36E-02 4.25E-03 0 0 0 0.0005 298 2.817E-04) INJ01)
You can enlist as many points one below another and save the file as a text file. And read through Define-Injections panel. Hope this will solve your problem.
Old   June 2, 2007, 06:40
Donia
thanks a lot
DPM Injections ABK FLUENT 14 August 26, 2013 02:40
Defining DPM Particle Injections with a UDF TedBrogan FLUENT 0 April 18, 2011 16:45
Coal Injections problem Carlo FLUENT 0 September 30, 2009 06:15
DPM injection ritmat FLUENT 6 June 26, 2007 02:38
How to define injections in DPM model lingo FLUENT 5 December 16, 2003 10:22
