radial turbine blade simulation with dynamic mesh 6dof(fluent)
Old   April 7, 2011, 14:28
Default radial turbine blade simulation with dynamic mesh 6dof(fluent)
mamadreza
mamyjooooon is on a distinguished road
help,help,help...............
Hi
i want to solve flow in a radial turbine wheel(with high RPM).
Because the flow work is done on the blades to make the blades rotating,I decided to use dynamics mesh with 6dof.
First, I'm not sure about my udf file, which is written bellow:
#include"udf.h"
DEFINE_SDOF_PROPERTIES(stage, prop, dt, time, dtime)
prop[SDOF_MASS] = 0.02;
prop[SDOF_IXX] = 0.0;
prop[SDOF_IYY] = 0.0;
prop[SDOF_IZZ] = 0.00000139;
printf ("\nstage: updated 6DOF properties");
(z axis is the axis of rotation)
Please tell me is it coorect?
Also because of memory limitation, I devide the turbine wheel geometry in similar sections and read one of them using periodic boundaries.
can I simulate the flow in this manner?
and if it is possible, which kind of zone (Rigid Body/Stationary) is defined for periodic zones?
Thank you. Kind regards, mamadreza.
mamyjooooon is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
how to obtain mesh file of cooled turbine blade rajesh kumar gupta FLUENT 0 October 18, 2007 04:18
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
