duct- Fletcher's technical note
Old   June 14, 2007, 21:58
Default duct- Fletcher's technical note
sheila
Hi all,
I'm doing simulation for a duct with AR=1 and comparing the results to the NASA technical Note by Fletcher (Experimental Investigation of Lift, Drag, and Pitching Moment of Five Annular Airfoil.
Right now, this is the detail of my simulation: 1) Duct based on Clark Y 2) M=0.13, V=44.2 m/s 3) Grid: 1 million 4) boundary: 20c (chord)-> pressure far-field, duct->wall, no slip 5) solver: coupled-implicit 6) viscous: S-A 7) alpha: 0 to 90 with 10deg interval 8) energy equation included because I use ideal gas (Fluent do it automatically)
the problem now is that the results deviate quite far from the experimental results. I have tried other BC, viscous, etc yet the results are still bad.
Can somebody help me?
Thank you in advance
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 04:23
usrbinld cannot find doug OpenFOAM Installation 19 November 4, 2010 14:15
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 05:35
Elements that limit the Courant number skabilan OpenFOAM Running, Solving & CFD 9 July 3, 2008 12:07
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 04:25
