UDF for heat transfer cofficient
Old   June 17, 2007, 12:17
Default UDF for heat transfer cofficient
rosol
Hi
I don't have any idea about using UDF .I need to calculate the distribution of Bulk temperature then the heat transfer cofficeint to calculate the overall heat transfer cofficient of heat exchanger. Please can any one explain the using of UDF and give me the way to calculate the mentioned parameters.
Thanks alot
Old   June 18, 2007, 10:52
Default Re: UDF for heat transfer cofficient
Jack Martinez
Hello!!
I am also going through same phase. Based on my experience, this is all I can suggest you
1. Use Execute_at_end macro
2. Obtain the temperature at Face and near wall region.
3. Calculate the heat flux (using mear wall approach)... I am informed that there is a predefined macro to extract the heat flux but I couldn't find it out.. if u find anything do pass it on this community ...
4. Use heat flux and the difference of above extracted temperature to calculate the HTC..
All the macros mentioned above are explained in UDF manual.. hope u can find them urself...
Jack ...
Old   June 18, 2007, 13:11
romio
Thank you Jack Martinez for your answer Please 1- Can you send me these macros becaouse I don't have suffecient experines about fluent and especially about using the UDF
2- Is the value of heat flux obtained from fluent directly from xy plot in certain surface tru ? and can I use it in my calculations by applying HTC=q/(Tm-Tw)to calculate heat transfer cofficient and then to calculate Nn from Nu=HTC*Dh/k.
Regards
Old   June 19, 2007, 08:06
rosol
Thank you very much Jack
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Mass Transfer UDF using Fluent VOF Anirudh_Deodhar FLUENT 0 February 7, 2011 15:10
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
