pls tell me a way to study fluent
Old   June 30, 2007, 00:31
Default pls tell me a way to study fluent
fayaz
hi! i'm an undergrad student. pls tell me a way to study the fluent software
Old   June 30, 2007, 00:51
Default Re: pls tell me a way to study fluent
Farhat
First of all you have to master CFD and for this you must go through elementary CFD books. I suggest you to read: CFD by T J Chung. You may need strong hold on Numerical Methods first to start learning CFD. After you feel conversant with Cfd try to may codes so that you gain insight into what CFD does. Then you can easily learn any CFD software. For Fluent you can go through its user manual.
Old   June 30, 2007, 08:21
Muhammad Usman Qureshi
kindly see the link below for an introduction to fluent.
http://www.mecheng.strath.ac.uk/home..._CFD_Class.pdf
Good Luck
Old   June 30, 2007, 16:52
taran
hi friend i am also new at fluent i m trying to go through the fluent tutorials , i got from cornell uni. website and some other s i downloaded.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 12:56
