How reduce calculation time?
Old   July 1, 2007, 09:07
Default How reduce calculation time?
Hesam
I need to solve 4 additional time dependent UDS equation and it takes long time, How I can reduce time? Should I use explicit solver? How I use it?
Thanks!
Old   July 1, 2007, 14:56
Default Re: How reduce calculation time?
taran
I think explicit solver takes more time than implicit becz large time steps are taken by implicit solver to converge to solution.
Old   July 2, 2007, 07:47
rosol
I thing you must be reduce the size of mesh
Old   July 3, 2007, 08:06
Phil
yeah I also agree.
I find though that the expensive models are 'reassuringly expensive' when using a complex flow.
Why don't you try to get access to a multi-processor grid? Although you are still limited to 8 processors unless you split the problem up.
And proper use of a stepwise solution process and relaxation factors and alligning the grid faces with the flow. The user guide probably has guidelines for getting a quick solution.
Phil
Old   July 3, 2007, 08:22
Hesam
Thanks alot!
calculation of time step aamer Main CFD Forum 8 December 8, 2010 03:26
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
