June 29, 2007, 11:09 |
How to import ProE model into Gambit
Can I import the ProE solid into Gambit? Can CFD connection do it?
Joe |
June 29, 2007, 14:35 |
Re: How to import ProE model into Gambit
yes you can. kindly see 'importing CAD geometry' in Gambit's User Guide.
June 30, 2007, 10:12 |
You can convert into IGS file, then open it in gambit
July 10, 2007, 17:44 |
import step, prt, asm, iges etc. Use either CAD connection tool or direct import with or without translation to ACIS kernel used by Gambit. Use Import>CAD to use built in granite kernel and prevent translation and loss of information resulting from translation.
Gambit Import error | GUEST | FLUENT | 7 | May 30, 2019 11:46 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Turbofan engine model meshing in gambit | vincentryan | ANSYS Meshing & Geometry | 9 | July 27, 2010 03:09 |
T-Grid / Gambit import and export | Riaan | FLUENT | 3 | January 6, 2006 10:16 |
How to import PARTRAN file to Gambit?! | anisa | FLUENT | 4 | June 7, 2005 04:24 |
