VOF - operating density
Like Tree1Likes
  • 1 Post By JSM
Old   June 29, 2007, 00:41
Default VOF - operating density
JSM
I am simulating refrigeration ejector in VOF multiphase model which has three phases(refrigerant vapor, liquid and water)
Is it necessary to specify the density of lightest fluid as operating density in the operating condition panel. what is the significance of this.
Thanks in advance,
JSM
Old   June 30, 2007, 06:24
Default Re: VOF - operating density
YY
If you interested with gravity effect you need to set the operating density for the lighter phase/fluid and if you not you have no need for it and keep everything default.
Old   July 2, 2007, 00:35
JSM
Hi YY,
Thanks for reply. I have one more clarrification in multiphase model. I am simulating condensation also in vof model. Only mass transfer UDF is enough or Source term UDF also needed.
Could you give me your personal mail id. I want to share the physics and your suggestions about my simulation.
with regards, JSM
ziziusan likes this.
operating pressure and operating density phil FLUENT 5 November 7, 2017 17:02
buyoancy and operating density Zeh FLUENT 2 March 24, 2007 07:22
operating density in buoyancy driven flow Marie-Anne Main CFD Forum 2 March 24, 2006 09:52
Specified Operating Density for Compressible VOF Andrew Wick FLUENT 1 November 14, 2005 04:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
