header file for strings in udf
Old   June 28, 2007, 02:37
Default header file for strings in udf
sangeeta
I am writing a udf in C++ which has strings. but when i compile my udF it says. Undeclared variable. So what is the solution for this? Can ne1 help
Thanks, Sangeeta
Old   June 28, 2007, 12:48
Default Re: header file for strings in udf
Allan Walsh
Your variables, or ones that you thought were defined in Fluent header files?
Old   June 29, 2007, 02:28
sangeeta
Its not my variables. there are some functions in C++ like round(). There are also not there in fluent compiler. SO help me with this also.
Thanks, Sangeeta B.
Old   July 5, 2007, 08:05
mayur
I think u can only use ANSI C in linux or VC++ in windows... try to use some macro
Old   July 6, 2007, 00:52
Sangeeta
Thank you mayur. I wl try this option
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
UDF giving warning, although used stdio.h header file jeevankumarb Fluent UDF and Scheme Programming 7 December 31, 2019 09:06
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
