How to fuse two differents geometries with Gambit?
Old   July 11, 2007, 07:07
Default How to fuse two differents geometries with Gambit?
Rémi CASSAR
I have two differents geometries A.dbs and B.JOU. I would like to fuse these geometries under Gambit in order to substract B-A...
But, when I open the journal B.JOU (with A.dbs already started), only the geometry A.JOU stays (a Gambit message talks that during the B.JOU open, A.dbs is closed)...
Help plz???
TK you.
Old   July 11, 2007, 09:08
Default Re: How to fuse two differents geometries with Gam
Gernot
If I have to put 2 geometries together i do it the following way. :
open first geometrie export it with file/export/ACIS nameoffile
open second geometrie file/import/ACIS nameoffile
I´m not sure if its the easiest way but it works
hope that helps
Gernot
Old   July 12, 2007, 04:08
Rémi CASSAR
Solved!!! Thank You!
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Possible to fuse two different Gambit geometries? A. S. FLUENT 2 January 26, 2007 18:22
GAMBIT Problem ,,,very thin geometries Meenu FLUENT 3 March 24, 2006 09:42
Gambit - Virtual Geometries (Pro's & Con's) James Date FLUENT 3 August 11, 2003 15:46
