gambit: how to produce hanging notes
Old   July 12, 2007, 11:54
Default gambit: how to produce hanging notes
Ralf Schmidt
Hi!
I want to create a 3D grid, that is very fine in a certain area, and very coarse around the area.
Now, It would be helpful, to have hex cells that allow hanging notes - that means, on one cell of the coarse grid, a number of fine cells could be attached.
It that possible in gambit???
Ralf
Old   July 12, 2007, 16:43
Default Re: gambit: how to produce hanging notes
jasond
I don't think so - if I am wrong, I hope someone will correct me. I have also wanted to generate a grid with hanging nodes, but Gambit doesn't even allow me to load a grid with hanging nodes.
Jason
Old   July 13, 2007, 11:34
Ralf Schmidt
Hi!
Thanks for your answer... What grid generator have you used for the grid with hanging notes?
What meshing programms will allow that kind of grid??
Any Idea? Ralf
Old   July 15, 2007, 11:27
jasond
I didn't actually use a grid generator - I had a mesh that Fluent had refined, and I wanted to modify it. I ended up going in a different direction.
Jason
Old   July 15, 2007, 16:52
red lemon
The only way to do this is to decompose into regions in Gambit and export meshes separately then merge cell domains together (in TGrid or Fluent) and create non conformal interfaces in the solver.
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Multiple hanging nodes in GAMBIT Partha Main CFD Forum 0 March 12, 2008 00:16
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
mesh generator, that can produce hanging notes? Ralf Schmidt FLUENT 3 July 23, 2007 13:44
mesh generator, that can produce hanging notes? Ralf Schmidt Main CFD Forum 2 July 14, 2007 01:57
