how can i list node temperatur by node location
Old   July 11, 2007, 03:09
Default how can i list node temperatur by node location
Ali Doustdar
hi i need report include node tempreture by node location, how can i get this in fluent?
Old   July 11, 2007, 17:31
Default Re: how can i list node temperatur by node locatio
red lemon
create a point surface and monitor/report this surface
Old   July 12, 2007, 23:48
Tomasz Bednarz
"Node values are calculated by fluent by averaging the values of the surrounding cells using a weighting defined by the inverse of the distance between the node and each cell centroid." This should help, since cell values are easy to get by UDF and then distances too...
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
How to find & view location of a node in CFX? Bill CFX 2 December 6, 2005 13:18
