Flow between 2 parallel flat plates
Old   July 13, 2007, 11:17
Default Flow between 2 parallel flat plates
pelli
Is it possible that modelling water flow between 2 parallel smooth plates with a laminar solution produces a non-linear correlation between the discharge and the pressure gradient. The problem is that unexpectedly my parallel plates model cannot be described by the cubic law, as there are quite high non linear pressure losses. i tried to refine the mesh but the results don't change. Can anybody help me, thanks a lot.
Old   July 14, 2007, 08:01
Default Re: Flow between 2 parallel flat plates
pelli
I think this could be helpful. I noticed that the longer the parallel plates the more the system approaches the cubic law. In fact, gradually increasing the length of my model from 32cm to 2m, gave a final linear relationship between the gradient and the discharge (with a very small error). Do you think this behaviour is caused by the presence of no flow boundaries on the upper lower and lateral surfaces? Thanks a lot
Old   July 14, 2007, 09:59
Joe
Boundary layers need time/distance to develop unless set correctly at the inlet BC.
2d cfd parallel plates Animeile CFX 1 April 21, 2010 16:24
supersonic flow over flat plate varunjain89 Main CFD Forum 1 March 23, 2010 08:26
problems for the flow over flat wall iilw1314 Main CFD Forum 0 March 19, 2010 04:53
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Parallel plates pelli FLUENT 1 September 5, 2007 20:16
