mesh generator, that can produce hanging notes?
Old   July 13, 2007, 11:37
Default mesh generator, that can produce hanging notes?
Ralf Schmidt
Hi!
does anyone know a grid generator software, that can produce a mesh with hanging notes?
Ralf
Old   July 13, 2007, 16:13
Default Re: mesh generator, that can produce hanging notes
Joe
Ansys Icemcfd
Sharc Harpoon
Old   July 18, 2007, 16:41
red lemon
ANSYS TGrid (hexcore) as well or just create multiple separate fluids and use utility tmerge or Fluent append case or TGrid TUI/GUI to merge meshes and create manual non conformal interfaces
Old   July 23, 2007, 13:44
red lemon
actually Tgrid and Gambit can both generate hanging node (non conformal) hexcore meshes. You have to ensure in both cases that the switch/default is set so that a transitional pyramid layer is not generated (causing it to be conformal) or it is not processed in tpoly to become conformal with the transitional layer as polyhedral cells.
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
gambit: how to produce hanging notes Ralf Schmidt FLUENT 4 July 15, 2007 16:52
mesh generator, that can produce hanging notes? Ralf Schmidt Main CFD Forum 2 July 14, 2007 01:57
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
Mesh Mignard FLUENT 2 March 22, 2000 05:12
