July 23, 2007, 17:44 |
free surface problem/time dependant
i have 2 problems.One is how do u put a time dependant inlet velocity and second is can we get the free surface diagram of water when it flows over a semi circle(the general case is when the flow is continuously there n the free surface is to be known eg a rock in the bottom of the pond...the case i want to know is when water flows in at the initial moment eg to demonstrate functioning of a weir say...please please help
July 23, 2007, 17:47 |
Re: free surface problem/time dependant
You can specify the velocity by writing a user defined function.
Regarding your second problem there is a tutorial in fluent. Check that out. |
July 23, 2007, 18:06 |
Yes use udf or use transient profile file (described in UG). To plot free surface create surface of volume fraction 0.5.
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 11:44 |
Free surface is below than expected..results are not good | mechovator | CFX | 24 | April 8, 2011 00:41 |
Submarine Free Surface | samwh | CFX | 7 | August 30, 2009 07:14 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
