July 23, 2007, 09:20 |
Wall Heat Flux Boundaries conditions
I want to include heat flux from some surfaces in the domain. When using Heat flux as a thermal boundary condition on a wall its gives the option of Heat Flux and Heat Generation. Do you need to input values for both?
July 23, 2007, 13:45 |
Re: Wall Heat Flux Boundaries conditions
No just import one. Then check using report>fluxes to be happy.
July 24, 2007, 09:34 |
This "Heat Generation Rate" is meant for a wall of non-zero thickness (you may find "Wall Thickness" above "Heat Generation Rate") which generates heat like a printed circuit board. If interested, you can read Fluent 6.2 manual 7.13.1 Thin Wall Thermal Resistance Parameters. Hope it helps, Ken |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 21:41 |
groovyBC nonuniform Wall heat flux | Shoonya | Main CFD Forum | 0 | August 11, 2010 13:03 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
wall heat flux or boundary source of energy??? | Albi | CFX | 1 | May 4, 2007 11:25 |
