symmetry....
Old   July 31, 2007, 08:17
Default symmetry....
oxalis
I simulate only half of my model, to reduce the grid needed. I use symmetry BC on the cutting axis (z).
My questions are:
1. in reference value, should I set the area as the area of the whole model (A) or only the area that I simulate (0.5 A)?
2. does fluent calculate the force for the whole model or only what I simulate (0.5 model) ?
3. is there any tutorial about this that I can refer to?
Thanks a bunch
Old   July 31, 2007, 09:51
Default Re: symmetry....
Joe
Old   July 31, 2007, 10:30
oxalis
thank you joe
really appreciate your answer
Old   July 31, 2007, 15:07
AAA
Hi
1) Is your model 2 or 3D?
2) Since a symmetry BC is nothing but a wall with a "slip" condition on it (as aopposed to a wall BC where the "no-slip" condition is applied on the wall), I presume that Fluent caculates the force for that specific domain.
3) The tutorial about flow in a tube bundle (heat exchanger) might help.
Regards
Old   July 31, 2007, 23:01
oxalis
my model is 3D.
if I model only half. I need to multiply the result by 2? so, the assumption is that both part (0.5 + 0.5 model) generate the same lift, drag and moment?
thanks for the reference
Old   July 31, 2007, 23:09
oxalis
i can't find the tutorial in fluent documentation. what is the tutorial number?
or can you give me a link.
thank you
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
radiation and symmetry Mark FLUENT 2 November 4, 2004 13:50
