some formula in Segregate solver?
Old   August 8, 2007, 05:00
Default some formula in Segregate solver?
sophie
hello,everyone!
i want to know the meaning of the nomenclature in these formular in fluent user's manual:
1)in Sectioniscretization of the Momentum Equation: ap*u = sum(anb*unb) + sum(pf*A . i) + S how to get ap,anb and S?
2)in Sectioniscretization of the Continuity Equation: Jf = Jf^ + df*(pc0-pc1) how to get Jf^ and df?
3.1)in .dat file, is the pressure value the solution cell value pc?
3.2)if i compute face forces using Section:Computing Forces and Moments: Ff = -sum((pf-pref)*A*n)
how can i get this pf from this pc(from3.1))? (suppose i use:
segregate solver, pressure:second order, density:second order upwind, moment:second order upwind, energy:first order upwind, pressure-velocity coupling:SIMPLE
to compute compressible,ideal gas density,steady flow,mach number less than 1.0 )
or did my scheme choose correctly???any suggestion?
thanks!
sophie
Old   August 8, 2007, 05:43
Default Re: some formula in Segregate solver?
Joe
3.2) Compute_Force_And_Moment (Domain *, Thread *, real CG,real Force, real Moment, boolean true/false);
See tut 12 UDF for usage.
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
