reversed flow &turbulent viscosity
Old   August 6, 2007, 07:18
Default reversed flow &turbulent viscosity
superfool
hi,everyone, I have a question that my case was converged ,but there are some additional message such as follows,could you tell me why and how to deal with them?
reversed flow in 5612 faces on pressure-outlet 10. turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 27284 cells ! 832 solution is converged
832 7.2256e-05 6.1473e-04 3.1136e-04 3.0135e-04 9.9980e-04 7.7691e-04 28:49:33 9687
Old   August 6, 2007, 07:37
Default Re: reversed flow &turbulent viscosity
farhan
check for boundary conditions and also for grid quality
Old   August 6, 2007, 07:41
superfool
my boundary conditions are pressure-inlet and pressure-outlet, i think my grid is ok,because my grid is multi-block structural grid
Old   August 6, 2007, 07:53
ritmat
try to change outflow for your outlet (OR velcoity inlet for your inlet)
Old   August 6, 2007, 07:59
superfool
when i use the Mass-flow-inlet Boundary, but do not get rid of that promblem
Old   August 6, 2007, 10:00
ritmat
mass flow inlet is mainly for compressible flow. Try like i said to remove the pressure outlet and change into outflow
Old   August 6, 2007, 19:51
superfool
pressure-outlet may be more suitable for my case,but i will try as your advice,thanks
Old   August 7, 2007, 02:00
Virag Mishra
Hi all I was am also facing the same problem, i tried changing the pressure outlet boundary condition to outflow but no successes. But got rid of it when i decreased the no of nodes in the mesh , but im unable to justify how it happened. any explanation.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 05:21
A problem: reversed flow in ... on outflow. vandadt FLUENT 10 November 10, 2009 16:40
Reversed flow on external aero problem Ben FLUENT 2 August 22, 2006 10:05
Combatting reversed flow tucker FLUENT 1 July 27, 2005 01:32
