FSCANF Problem
Like Tree4Likes
  • 2 Post By DK
  • 2 Post By D.Martelli
Old   August 10, 2007, 10:07
Default FSCANF Problem
DK
I'm trying to load velocity data from a file using the following code:
/***********BEGIN**************/
int maxcent = 1;
int a = 0;
int b = 0;
double tempvel;
double velprof[1000][8]; /* make sure # faces <= 1000 */
double test1;
FILE *fi2;
fi2 = fopen("velprof4.txt", "r");
if (fi2 == NULL)
printf("*\nERROR - CANNOT OPEN THE FILE\n*");
else
printf("*\n File Opened. ID is %d\n", fi2);
while (a <= maxcent)
b = 0;
while (b <= 7)
fscanf(fi2, "%g", &tempvel);
velprof[a][b] = tempvel;
printf("%d %d %g\n", a, b, velprof[a][b]);
++b;
++a;
fclose(fi2); } /***********END**************/
The input file was created in a text editor and is: 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0; 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0;
The representative output from FLUENT for the velocity matrix is:
File Opened. ID is 18001056;
0 0 5.26354e-315
0 1 5.30499e-315
0 2 5.32571e-315
0 3 5.34643e-315
0 4 5.3568e-315
0 5 5.36716e-315
0 6 5.37752e-315
0 7 5.38788e-315
1 0 5.39306e-315
1 1 5.39824e-315
1 2 5.40342e-315
1 3 5.4086e-315
1 4 5.41378e-315
1 5 5.41896e-315
1 6 5.41896e-315
1 7 5.41896e-315
So the velocity values in the matrix are wrong. Any ideas?
Thanks,
czhao86 and myaghoobi2 like this.
Old   September 15, 2011, 08:57
Default fscanf problem
Daniele
D.Martelli is on a distinguished road
Hi i had got the same problem and i soved it defining the variable as float and not double...try it and let me know
by daniele
ghost82 and Alimohamadi_nasr like this.
D.Martelli is offline   Reply With Quote
Old   March 11, 2013, 06:18
Ali Mohamadi
Alimohamadi_nasr is on a distinguished road
by daniele
dear D.Martelli many thanks, it also works for me.
Alimohamadi_nasr is offline   Reply With Quote
Old   June 4, 2014, 07:17
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I got crazy with this fscanf....thanks Martelli, declaring the variable as float works!
Daniele
ghost82 is offline   Reply With Quote
Old   June 24, 2014, 11:58
Select One...
eneja is on a distinguished road
Where do you use this code? I thought UDF needs DEFINE macro...
eneja is offline   Reply With Quote
Old   June 24, 2014, 18:01
ghost82's Avatar
Rick
Hi, in a few words,
fscanf is a C function to scan a file for its content.
Macros are written in C language to communicate with fluent.
Inside macros you use C language, so you can use the fscanf function.
Daniele
Old   June 26, 2014, 03:53
Select One...
Thank you for your explanation, but in the code from above, there is no macro, that would communicate with fluent. I assume that part is left out, or is it possible to execute code as it is?
Thanks
Old   July 7, 2014, 12:19
sescobar is on a distinguished road
I was having the same problem. Changing variable from real or double to float worked perfectly.
Thanks
sescobar is offline   Reply With Quote
Old   September 19, 2017, 03:33
Default fscanf in udf
mohammad
myaghoobi2 is on a distinguished road
Hi
Changing the double or real to float will work I think because we have used "%g" in fscanf function
myaghoobi2 is offline   Reply With Quote
Old   April 6, 2024, 16:30
Dilz is on a distinguished road
Thanks a lot guys. This works !!
Dilz is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
