Question about Two-Sided Walls
Old   August 15, 2007, 13:19
Default Question about Two-Sided Walls
justinF
I was wondering how fluent handles heat transfer at two sided walls where fluid meets solid. I can't seem to find anything about it in the manual.
Does it use some kind of correlation to find a heat transfer coefficient from the Nusselt number or does it assume the wall temperature is equal to the temperature at the very edge of the fluid? Something else?
I have no idea how this condition works, which makes it difficult to understand if there are limitations associated with using it.
Old   August 16, 2007, 13:50
Default Re: Question about Two-Sided Walls
lucus
It will calculate a heat transfer coefficient given the flow characteristics, then it will solve the convective heat transfer equation.
Which coorelation it uses to solve for h; i don't know.
Old   August 16, 2007, 17:34
justinF
Thank you for the reply. I has assumed it used something similar to the Dittus-Boelter equation but was unsure.
question about uds tanven FLUENT 2 July 5, 2015 11:22
Wall boundary condition (a very simple question) safa_c FLUENT 1 August 15, 2010 05:05
Boundary Condition question for Cooling Water Pumps Bay Simulation Jaimito FLUENT 0 August 3, 2010 06:58
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
