skewness of polyhedral elements
Old   August 20, 2007, 19:39
Default skewness of polyhedral elements
Neo
Anyone know how to determine the skewness of the polyhedral elements? or Is it the same method for others shape. I converted tetra mesh into polyhedral. The outcome is that the maximum skewness became zero.
Old   August 20, 2007, 20:47
Default Re: skewness of polyhedral elements
Carlos
Yes I'm sure you measure skewness in the same way in Fluent. The main advantage of polyhedral cells is that they have a much lower skew value, thats one of the reasons why poly-meshes give faster simulation times. Try looking at average values too.
Regards,
Carlos.
Old   August 21, 2007, 02:36
Razvan
Unfortunately, the "skewness" concept is not applicable to polyhedral cells just as for the other, ordinary shapes like tetrahedron or hexahedron. The reason for that is very simple: polyhedral cells may have 7, 8, 9, an so on, up to 16 (perhaps...) faces, and one cannot easily define an ideal shape to be compared with all these cell shapes. Nevertheless, there is at least one quality criterion defined in FLUENT that applies to polyhedral cells, but it can be accessed only through TUI: the squish index.
Two possible quality criteria (that could be inplemented, in my opinion):
- "sphereness" = nodal averaged normal distance to the circumscribed sphere (the closer to 0, the better the quality of the polyhedral cell);
- "convexity/concavity" = the normal distance between any node and a face constructed using the surrounding nodes only (should be >=0, if calculated considering the positive direction the normal direction pointing outside of the cell).
I repeat, these criteria are not implemented in FLUENT, they are just suggestions for the developers.
All the best,
Razvan
Old   August 21, 2007, 18:52
Neo
Thank you very much guys. Can you tell me how monitor "the squish index"?. Can you tell me some commands which lead to it?
Old   August 22, 2007, 02:18
Razvan
After converting your grid to polyhedral, type "grid/quality" in the TUI, and automatically the solver will calculate this parameter for all the faces and the cells of the grid.
Razvan
Old   August 22, 2007, 04:08
Neo
thanks for the answer.
Old   September 4, 2007, 10:37
Default Re: skewness of polyhedral elements *NM*
chouaib
Old   April 5, 2016, 12:14
Default What if Cell/ Face Squish index not shown in mesh/quality
Polytimi Sofotasiou
Polysf is on a distinguished road
Initially I wasn't able to find the cell or face squish index to evaluate the polyhedral quality mesh.
What I had to change was the amount of mesh details reported, by changing the value in verbosity from 0 to 2 by:
"mesh/check-verbosity 2"
Then all the mesh info were shown!
Polysf is offline   Reply With Quote
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 18:47
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
