Unsteady Solution
Old   August 21, 2007, 06:46
Default Unsteady Solution
Dave
Hi everyone.
Im a bit frustrated with the unsteady solver. I am running a simulation of flow over a turbine and have the following settings;
time step size: 0.01 no of time steps: 40 max iterations per time step: 5
After every 5 iterations, an image of the iso-surface i defined to show a velocity profile over the turbine flashes up and the image file goes into my hard drive. On checking the first 20-odd profiles i realised that nothing is actually changing on them...is there a reason for this?
Cheers
D
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 05:49
How to get the solution of last time step? lzgwhy Fluent UDF and Scheme Programming 0 September 15, 2010 22:23
residual plot after solution reset plaunie STAR-CCM+ 1 April 3, 2010 06:53
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 07:52
UDF solution variable for time-averaged mass frac? A. S. FLUENT 0 May 14, 2007 16:44
