Finding the node temperature (not cell)
Old   August 21, 2007, 18:48
Default Finding the node temperature (not cell)
Parsa Zamankhan
Hi
Is it possible to find the temperature of nodes (not cells) through udf?
Thanks Parsa
Old   August 22, 2007, 10:46
Default Re: Finding the node temperature (not cell)
Phil
Isn't temperature stored at the cell centre rather than nodes for finite volume discretization?
If so then the answer is no, there aren't temp values at nodes.
Phil
Old   August 22, 2007, 11:46
Parsa Zamankhan
Thanks Phil. I thought Fluent might interploate among the cells for the nodes temperture. In fact the output file of Fluent for Tecplot, provides the information ( including the temperature)at the nodes (I think).
Parsa
Old   August 22, 2007, 15:29
Phil
Ah,
Have you looked at the UDF guide to see it you could access them quickly that way?
Phil
Old   August 22, 2007, 15:38
Parsa Zamankhan
I could not find anything. It seems except velocity components , the other quantities are available just in cell's center.
Parsa
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
Temperature limit 1.00 k in cell MANOJKUMAR FLUENT 0 February 24, 2006 08:13
Node centered and cell centered. Confused. Main CFD Forum 9 August 29, 2003 13:54
finding exact temperature....Urgent.. Puck FLUENT 5 July 22, 2002 01:24
