open channel VoF flow
Old   August 23, 2007, 10:54
Default open channel VoF flow
Jim
I am trying to model flow through an open channel with a submerged pressure inlet. The situation is in a river so the inlet pressure is constant and the outlet river level is known and constant. I set up the implicit VOF model and define the input pressure but the downstream water level never rises above the height of the inlet. I want the water to be 3m deep with a 1m high inlet fully submerged injecting water to the channel.
Any ideas about what to do next? Am I using the correct model and am I on the right track?
Thanks in advance
Old   August 23, 2007, 19:47
Default Re: open channel VoF flow
Joe
This class of problems is normally solved by using a mass flow inlet and a hydrostatic outlet pressure bc. As a hydrostatic pressure field will develop your bcs need to accommodate this.
boundary conditions in FLUENT VOF for open channel flow newcomer Fluent Multiphase 32 May 4, 2020 07:28
3d free surface open channel modeling (vof) hamed_roozegar FLUENT 17 March 25, 2016 04:01
Open Channel Flow Boundary Conditions TWaung STAR-CCM+ 2 October 7, 2011 00:37
Open channel flow motaba Main CFD Forum 4 March 26, 2011 03:22
Open Channel Flow OffshoreStructuralEnginer CFX 13 August 3, 2010 21:31
