August 26, 2007, 08:39 |
Error access violation
I modelized a turbine with Gambit,then I export it in Fluent. I set up the solver and the Boundaries conditions (Moving wall, Pressure inlet and Pressure outlet). When I want to initialize the solution Fluent write :
Error : Fluent receive a fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data 3. Exit the program and restart to continue. 4. Report error to your distributor Error Objet: () Can you help please. Thank you in advance Marc |
Segmentation violation | louiza | FLUENT | 16 | June 27, 2017 15:41 |
Segmentation Violation | Corentin | FLUENT | 1 | February 13, 2011 01:07 |
Defining Multiphase by text and by gui = different result and Segmentation Violation | RPJones | FLUENT | 0 | June 9, 2009 16:24 |
segmentation violation | wasan | FLUENT | 0 | December 23, 2008 11:37 |
Access violation - Help please | AlwaysLearning | FLUENT | 3 | August 22, 2006 12:21 |
