September 9, 2007, 18:13 |
Significance of COURANT nUMBER
Hi everyone, I am doing supersonic flow study in a combustor.I want to know how important is the effect of Courant number on the solution ,convergence etc. I am presently using Courant number of 0.5. How far can I change it from my present value to get better results.
Regards sridhar |
September 10, 2007, 12:56 |
Re: Significance of COURANT nUMBER
A CN of less than 1 is always satisfactory for an implicit solver. Practically a RMS CN <= 1 and MAX CN <= 5-10 is usually satisfactory for adaquate accuracy for an implicit solver. You can go bigger but you must then show solution insensitivity to a CN > 1.
September 12, 2007, 11:47 |
thanks for the rply .. just help me out with another small doubt of mine ..mine is an injection problem and the main flow is supersonic with sonic injection .I would like to know . should I start with UNSTEADY solution or start with STEDY SOLN and then switch to unsteady solution.. Please suggest ..thanks
September 26, 2007, 16:14 |
Start with a steady solution and then do the unsteady soultion.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 18:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
COURANT NUMBER | Ferreira | Main CFD Forum | 23 | February 26, 2006 18:10 |
