how to stop FLUENT batch job and save the results?
Like Tree1Likes
  • 1 Post By sophie
Old   September 20, 2007, 21:41
Default how to stop FLUENT batch job and save the results?
sophie
how to stop FLUENT batch job and save the results in TUI?
1)stop and save,exit FLUENT
2)stop and save,continue the computation
thanks a lot!
Old   September 21, 2007, 05:04
Default Re: how to stop FLUENT batch job and save the resu
Joe
Seach the manual for checkpointing.
Old   September 21, 2007, 05:15
sophie
i read the manual,but not quite understand it
could you tell the detail?
thanks a lot
Old   September 21, 2007, 05:18
mAx
There are two checkpointing modes:
* check-fluent - After the current iteration is complete, Fluent will save the current solution to case and data files, then continue running. * exit-fluent - After the current iteration is complete, Fluent will save the current solution to case and data files, then exit.
To do this on a UNIX machine:
* Create a text file with either the filename "check-fluent" or "exit-fluent" and place this file in the directory /tmp. The contents of the file are irrelevant - Fluent will only check to see if a file with one of the above names exists in the /tmp directory.
To do this on a PC/Windows machine:
* Create a text file with either the filename "check-fluent.txt" or "exit-fluent.txt" and place this file in the directory C:\TEMP. The contents of the file are irrelevant - Fluent will only check to see if a file with one of the above names exists in the C:\TEMP directory.
Notes:
* DOS requires the .txt extension on the filename. * Once a check-fluent or exit-fluent is performed, Fluent will automatically remove the file from /tmp or C:\TEMP. Thus, if you wish to perform another check-fluent, simply create a new file. * Fluent will append the current iteration counter to the filename so that unique filenames will be created if multiple instances of check-fluent are performed.
Old   September 21, 2007, 23:07
sophie
thanks a lot! i finally solve the problem!
i write my .jou as follow:
;case 1)save and exit (set! checkpoint/exit-filename "your directory.txt") ;case 2)save and continue (set! checkpoint/check-filename "your directory.txt") ... and type
touch your directory.txt
the process will case 1)stop,and Fluent save the .cas.gz and .dat.gz file,then exit.
case 2)stop,and Fluent save the .cas.gz and .dat.gz file,then continue the iteration.
thanks for you guys' help!
sophie
Zari likes this.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
How to save images of contour plots during parallel job Neil11 FLUENT 5 September 23, 2010 19:06
terminating batch job on Windows bohis FLUENT 0 January 6, 2009 10:50
How to stop bproperlyb a job openfoam_user OpenFOAM Running, Solving & CFD 7 October 13, 2008 02:36
