USMAN
Rep Power: 16 ![]() |
hi everyone,,
i am simulating store separation in Fluent using 6DOF solver.The mesh size is 2.3 million and it is tetrahedral grid.Now the problem is if i run it on a single node, my system goes out of memory.So i have to use parallel processing.But in parallel processing,after 1st time step, i get the following error. unable to read cmd header on pmi context:generic socket failure........ and MPID_SOCK_WAIT:The specified network name is no longer available... and befor that ,durine the compilation of udf,i get a warning as well i.e; the specified directory is not shared.This may cause file opening issues across the network. I am using Windows xp ,Quad node processor with 2 GB of ram. Can anyone help me in this regard?? Regards |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
sharing the directory for parallel 6DOF UDF... | usman naseer | Main CFD Forum | 1 | September 6, 2010 04:09 |
parallel 6DOF UDF.... | usman naseer | FLUENT | 1 | February 18, 2010 14:56 |
sharing the directory for parallel 6DOF udf.... | usman naseer | Fluent UDF and Scheme Programming | 0 | February 16, 2010 12:37 |
sharing the directory for parallel 6DOF udf .... | usman naseer | FLUENT | 0 | February 16, 2010 12:29 |
