Is there need to use BL in 2D pipe
Old   September 29, 2007, 15:35
Default Is there need to use BL in 2D pipe
Salam
Hi I am using 2 D pipe I consider it as a rectangle with four vertices I increases the number of mesh near the wall by using first length and last length options available with mesh edges menu so I need to ask : is it necessary to create BL near the wall in this case?
Thanks to any notes Salam
Old   September 30, 2007, 11:40
Default who can answer my question
salam
Is there anybody can answer my last question? I need to know if my simulations is correct without BL or no? pls guide me.
Thanks salam
Old   September 30, 2007, 15:45
Default Re: Is there need to use BL in 2D pipe
H.A.S
As i Know , absolutely yeah ;
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
pipe in pipe heat exchanger JohannV FLUENT 3 December 3, 2009 02:53
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
