HELP please! urgent.
Old   October 1, 2007, 10:01
Default HELP please! urgent.
vincent
Hello, can anybody tell me what is hydraulic diameter? if i am simulating a 2 dimensional air flow simualtion around a 4.465m length and 1.42m heigh car in a 60 x 35 meter square wind tunnel, what hydraulic diameter should i set? what are the area and length values should i set in the reference value? thanks.
Old   October 2, 2007, 09:39
Default Re: HELP please! urgent.
PratiK Mehta
hello
Hydraulic diameter- its a diameter with which you will calculate Reynolds number for the bodies like rectangular shape (Wind tunnel dimensions )
D_H= (4*Area )/perimeter
http://en.wikipedia.org/wiki/Hydraulic_diameter
lenght should be your highest dimension of the domain. Area will be used to compute the forces on the surface.
Length which is used in the computation of the moment coefficient.
Old   October 4, 2007, 11:35
vincent
thanks a lot, Pratik..it really help me a lot. i still not clear with the length u mention, may i know, what did u mean by the "highest dimension of the domain"? is't the car length? if for 2D simulation we need to set or not?
Old   October 5, 2007, 04:13
Faik Hamad
I think U = (4.465 +4.465 + 1.42 +1.42)
Old   October 5, 2007, 09:18
PratiK Mehta
Lenght means the charactertic dimension ,here in your case it would mean Height of the car from the ground
Old   October 8, 2007, 10:24
vincent
ok..thanks a lot.
Old   October 8, 2007, 10:25
vincent
i see, thanks a lot.
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
very urgent pleasade:Cl and Cd values for airfoil Liaquat FLUENT 2 April 27, 2006 12:20
