October 12, 2007, 17:00 |
Dynamic Mesh - Ball in Cylinder
I am trying to learn more about the dynamic meshes in fluent, and have what I think should be an easy model to setup. I created and meshed a cylinder with sphere cut out of it, and created a zone at the sphere. I am confused what to do in the dynamic zone form under Motion UDF/Profile. I want to just have the ball move at a constant velocity for a given amount of time in an unsteady case. When I create the profile I do not see how to set this velocity. I looked in the tutorial, but they use a UDF, which seems very unnecessary for just a constant movement. Thank you in advance, Hamish
October 14, 2007, 13:32 |
Re: Dynamic Mesh - Ball in Cylinder
When you want the motion to be constant to be constant velocity, you just use the GUI panel ... no need to use the UDF.
October 14, 2007, 18:57 |
When I just set the constant velocity in the boundary condition, I can get the solid ball to move, but the fluid mesh does not modify with it, is there a way I need to tell it how the ball is in contact with the fluid? Or am I going about this the completely wrong way? Thanks, Hamish PS Sorry if these are stupid questions, I have found myself out of my depth on this.
October 15, 2007, 15:51 |
You have to tell the solver to what are the zones to be remeshed. In your case you can make a concentric cylinder aroud 5 or 6 diamaters bigger than the ball. And inform the solver to remesh the zone. I would suggest you to try the tutorial in Fluent.
I am independent freelance consultant. I would not able to help you more than that for free. Thanks Venkatesh V |
October 26, 2007, 04:03 |
Hi Hamish,
For your problem (constant velocities), you can use profile files which are very easy to make and under-stand. When you will read profile file in your case then automatically you will get profile in motion attribute panel. you can define any angular and linear velocities at any time with the profile file.....please check more details in fluent manual. Regards Sunil Damira |
October 26, 2007, 08:43 |
Yes thank you I did end up using a profile, and it worked well.
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
Dynamic mesh update problem. | David | FLUENT | 3 | March 15, 2012 05:02 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
ICEM block mesh with a ball in a cylinder tube | Li | CFX | 6 | August 11, 2008 05:44 |
Problems using dynamic mesh and 6dof solver | Brett | FLUENT | 0 | March 3, 2006 17:45 |
