angular momentum with swirling flow
Old   October 20, 2007, 11:18
Default angular momentum with swirling flow
Roberto
Hi, I am working with CFD to analyze a swirling burner with a square section combustor. When I calculate the angular and the axial momentum inside the combustor, it decreases the more I check downstream to the burner exit. Do you know what would create a decrease in the angular and axial momentum inside a square section combustor? Should the swirl number variate inside the combustor?
Thank you very much for your help.
Swirling flow as a boundary condition hami9293 FLUENT 0 November 2, 2010 07:09
2D swirling flow NOT axisymmetric Giuki FLUENT 3 May 30, 2009 00:30
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 21:03
help! too highly swirling flow in a cyclone lcw FLUENT 1 November 22, 2005 08:17
flow in pipe with momentum and energy source Atit Koonsrisuk CFX 3 March 29, 2005 16:58
