UDF Compiling Problem (64 bit machine)
Old   October 23, 2007, 23:14
Default UDF Compiling Problem (64 bit machine)
woo meng wai
When I compile the UDF, the following message appears:
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2143: syntax error : missing '{' before ':' c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':' c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc' c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';' c:\fluent.inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
I am running on the following system:
Windows XP Professional Edition 64x edition Version 2003 service pack 2 Intel(R) Core(TM)@ CPU Microsoft .NET Framework Version 2.0 Redistributable Package (x64)
FLUENT 64bit microsoft visual C++ 6.0
The problem occurs in both 2d and 2ddp. This UDF can be previously successfully compiled on a 32 bit machine using microsoft visual express 2005. does anyone have any idea why is this occuring?
Compiling / Loading UDF Martijn FLUENT 1 December 16, 2008 19:06
UDF problem/32 bit vs. 64 bit RE13 FLUENT 2 February 25, 2008 11:31
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 14:45
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 03:21
