AMG divergence and boundary layer mesh
Old   November 4, 2007, 17:24
Default AMG divergence and boundary layer mesh
Justin
Hi, all
Recently I occurred the problem of AMG divergence: pressure correction. Firstly I checked my boundary condition by other model, it was fine. Then I changed the URF to 0.1 and 0.5 for pressure and others, but it was still diverged. I tried to use density based solver, it is no problem, but it needed more memory. So I tested the meshes. I found that if I deleted boundary layer mesh around walls, it also did work well.
My question is why the boundary layer mesh( y+ =1)can cause the pressure correction error, while no problem for coupled solver?
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 11:30
Error: divergence detected in AMG solver: pressure correction sabin FLUENT 1 September 3, 2011 04:53
Divergence in AMG solver! what does it mean ?!! diwakarsingh64 FLUENT 0 December 23, 2010 06:14
Divergence detected in AMG solver: x-momentum arashm FLOW-3D 2 August 14, 2010 04:54
How to calculate the divergence on the boundary? maximus Main CFD Forum 1 July 11, 2004 02:35
