UDF Data Access Macro
Prev Previous Post   Next Post Next
Old   November 6, 2007, 20:23
Default UDF Data Access Macro
Woo Meng Wai
I am running a DPM model with vaporizing droplets (1 vpaorizing species). I require to access the heat and mass transfer coefficient used by the solver for the vaporization law. does anyone know of the macro that we can use to access them?
Alternatively, if the coefficients can't be accessed, they can be calculated with the following properties:
particle reynolds number viscosity (continuous phase) specific heat capacity (continuous phase) species diffusion coefficient (in the continuous phase) particle to fluid relative velocity prandtl number schmidt number
I tied looking in the UDF manual but can seem to find the macro to access these properties. Hope someone can help. It will be great if we can access the heat and mass transfer coefficients directly.
Woo
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
accessing solver data with UDF macros Dushan FLUENT 1 April 22, 2017 21:05
how to access a variable in DPM within a UDF patrick FLUENT 13 September 15, 2010 08:38
Use of Experimental Data in fluent using UDF anvitaa.sharma FLUENT 2 February 18, 2010 10:46
Extract Data from Polyline in a Macro (Tecplot) Joe Main CFD Forum 0 September 5, 2008 03:46
