Particle Size Distribution (PSD) in fluidization
Old   May 21, 2011, 14:12
Default Particle Size Distribution (PSD) in fluidization
Sangram Roy
sangramroy is on a distinguished road
I am working on simulation of a circulating fluidized bed. Its assumed that the entire batch of solids are of same size (identical dp), though in reality it is not the case. Is it possible to define a particle size distribution (PSD) for such cases? Do I need to define a UDF to mention PSD?
sangramroy is offline   Reply With Quote
Old   May 22, 2011, 02:40
alighaffari
alighaffari is on a distinguished road
Hi
you can use Rosin-Rammler distribution model if you are using DPM model in fluent for inlet particles size distribution. you can eighther use UDF if Rosin-Rammler distribution model is not appropriate for your case study.
alighaffari is offline   Reply With Quote
Old   May 22, 2011, 04:00
Sangram Roy
Is it possible to implement the said model while using Eulerian-Eulerian approach?
Old   November 2, 2011, 04:19
minh nguyen van
ch3coohminh is on a distinguished road
Originally Posted by alighaffari View Post
Hi
Hi.thanks you so much for suggests.Can you give me UDFS of ROSIN RAMMLER distribution ??
ch3coohminh is offline   Reply With Quote
fluidized bed
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
