October 29, 2007, 16:25 |
Flotation Cell Help
Good evening.
I am trying to create a rotor stator system wit flotation cell. i am using something similar to a outokumpu impeller. a rotating set of blades inside a diffuser. in Gambit, i have done to scenario's , i have made 2 volumes, with one common cylindrical face, (one rotating inside the other), and 2 volumes with 2 common cylindrical faces ( one overlaps the other). the interface of these cylinders sits inbetween blades and diffuser within the fluid zone not on the solid. Howver i cant seem to get this to work in Fluent, i have read all the manuals. does any body have any insight on this topic? |
October 29, 2007, 19:15 |
Re: Flotation Cell Help
What type of error does Fluent show you? What type of MRF are you using, sliding mesh, mixing plane? Cheers, Javier
October 30, 2007, 05:03 |
I am using sliding mesh, if i use the way of two volumes with 2 interface faces over lapping i get a nopositive volume exists message, and if i use the two volumes split in two - i just get either Fatal error - or simply Divergance detected before any iterations occur.
Help Me, what's the Cell Above any given cell in 3D. | gomane8 | Main CFD Forum | 3 | September 11, 2011 21:29 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
How to determine the direction of cell face vectors on processor patches | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | October 27, 2009 08:47 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
